Installation problem
Unable to install. My PC runs Windows XP, whereas CCleaner gives message "Ccleaner requires Windows 2000 or later". Pls help.
Have you tried the slim or portable version?
http://www.piriform.com/ccleaner/builds
Which version are you trying to install and where did you download it?
http://www.piriform....ccleaner/builds
thanks.. tried with portable version. it worked..
