Hi Luc,
Thanks for the logs, there's still afew problems showing so this will take afew steps to help you get the machine clean again.
Run Hijack This and choose Do A System Scan then place a check next to these entries
O2 - BHO: Class - {0A5F82EA-0DD1-4033-7C1A-F9F2F5775550} - C:\WINDOWS\uvwog1.dll (file missing)
O23 - Service: UpdHab - Unknown owner - C:\Program Files\Fichiers communs\System\swA.exe
Close all open browser and other windows except for HijackThis and press the Fix Checked button
Please download the Suspicious file Packer from Safer-Networking.org and unzip it to your desktop.
Run SFP.exe.
Please copy the following lines into the Step 1: Paste Text window:
C:\WINDOWS\apisv.exe
C:\WINDOWS\msgh.exe
C:\WINDOWS\PATCH.EXE
C:\WINDOWS\system32\atlws32.exe
C:\WINDOWS\system32\ntlg.exe
then click "Continue".
This will create a .cab file on your desktop named requested-files[Date/Time].cab
Please then visit the below link
http://www.bleepingcomputer.com/submit-mal....php?channel=27
In the Link to topic where this file was requested: area type Ccleaners, Click Browse and then locate the requested-files.cab archive on your desktop then click Send File
Once it shows
Your file was successfully submitted. Please let the user helping you know that you have submitted the file.
You can then close that site and continue with the below steps
Download the Gromozon remover from here
http://www.prevx.com/gromozon.asp
Run the tool and follow the prompts, click No if it prompts you to install prevx as its a trial version and isnt required here, when its finished please post the gromozon_removal.log into your next reply,
Goto Start > Run > copy and paste
cmd /c net user>%systemdrive%\user.txt & start notepad %systemdrive%\user.txt
Press OK and post the contents of the C:\user.txt file back on here
cmd /c regedit.exe /a/e %systemdrive%\regresult.txt "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\SpecialAccounts\UserList" & start notepad %systemdrive%\regresult.txt
Press OK and post the contents of the C:\regresult.txt back
Please then upload the Requested-files.cab archive, post back the Gromozon_removal log, C:\user.txt and C:\regresult.txt then we can take it from there
Thanks
Andy
