I've downloaded Defraggler but the installer never pops up.
You need to run the installer.
Richard S.
Richard S.
I would love to but I cant find it. it would normally "pop up" after the download but it never does.
okay so where do I find the installer?
Best way is maybe to download it again from filehippo, remember where you saved it, and run it from there.
Filehippo is http://www.filehippo.com/download_defraggler
click on "Download Latest Version 4.04MB" at top right.
Select where to put it and remember that location.
That will download a file called dfsetup121.exe
Navigate to the file, dbl click it, and wallah, defraggler will install.
If you want to find out if you actually downloaded it before, open windows explorer, right click on C: drive, click on search, and enter "dfsetup*.exe" without quotes. If you saved it to C: drive somewhere, that will find it, and you can decide what to do with it.
