individually installation path?
hi fans,
i have only the old installation file from december 2013 and dont know if it has since been adapted...
the standard install path in w8.1 is "C:\Program Files (x86)\Agomo"
could insert a user selected install path?
Hello,
I downloaded the Agomo installer today and installed it on a new system.
The installer does not ask for an installation path, I just can install it or not install it.
So I also support this idea!
Greetings
OLLI
