Index.dat Suite v2.10.1
Changes:
Added: Support for Windows XP Service Pack 3
Added: Support for Windows Vista Service Pack 1
Index.dat Suite
Overview
Index.dat Suite is a rather unique program that allows you not only to delete the index.dat files, temporary internet files, temp files, cookies and history, but it also allows you to view the index.dat files on your system.
Index.dat Suite's current features include;
  • View, delete and backup index.dat files
  • View and delete Temporary Internet Files (TIF)
  • View and delete Cookies
  • View and delete History
  • View and delete Temp files
  • View and delete Recent Documents
  • Delete Typed URL's
  • Delete Prefetch folder contents
  • Auto-generation of batch file to assist in deleting the index.dat files in DOS.
  • Optional add to RunOnce, Run or WinLogon registry key
  • Optional deletion of swap file (9x users only)
  • Optional defrag after file deletion
  • Optional backup/deletion of NTUser.dat.log file (2K/XP/Server 2003 users only)
  • Optional System Restore point creation
  • Full application logging
http://support.it-mate.co.uk/?mode=Product...=index.datsuite
Discussion:
http://forum.hosts-file.net/viewforum.php?...f18faa212c5c2c7
What is it? I'm not sure what exactly i would use it for....
It is a comprehensive tool to look at and manage the index.dat files stored on your system.
Read about it:
http://en.wikipedia.org/wiki/Index.dat
CCleaner will clean the index.dat files at next reboot if you have the Delete Index.dat files option selected.
