index.dat not properly deleted
Hi,
http://www.acesoft.net/index.dat%20viewer/....dat_viewer.htm pointed me to the right direction.
I've selected the index.dat checkbox in CCleaner. Analyzed and deleted content, did a reboot.
Still winspy was able to display the content of index.dat - because CCleaner did even not delete the index.dat file.
C:\documents and settings\username\local settings\Temporary Internet Files\Content.IE5\index.dat
Scary winspy! Using CCleaner 1.38.485
Tolomir
Apon restart the file would have been recreated, that is why you can still find and open the index.dat file.
Does your Index.dat file still contains the same entries before and after restarting, or is it empty?
http://spywareinfo.com[/url'> ']The next time you log on, Windows will try to open the index.dat files, find they are missing and recreate them and their folders from a default template. [read more]
Ok - upgraded to latest CCleaner version.
Afer a reboot it's still there - full with 800+ entries.
Btw. my path is: C:\Dokumente und Einstellungen\tolomir\Lokale Einstellungen\Temporary Internet Files\Content.IE5\index.dat
Maybe CCleaner cannot handle the German path?
Tolomir
Well, I just checked and it deletes it all on our pc, so maybe it does have a bug with regards to the language.
Just check what index.dat files CCleaner says it will delete:
Run CCleaner, click analyze, look through the list untill you find index.dat (there should be two entries),
where does CCleaner find the .dat files (if it finds them)?
It "finds" just this one:
Zum L?schen markiert: C:\Dokumente und Einstellungen\Tolomir\Cookies\index.dat
Not the important one:
C:\Dokumente und Einstellungen\Tolomir\Lokale Einstellungen\Temporary Internet Files\Content.IE5\index.dat
Tolomir
Tolomir
IMO this is the problem. Since in my italian XP i must
translate "Local Settings" (and also "Application Data")
for get CCleaner working in such paths.
Of course this problem doesn't affect english users. :unsure:
Edit: Let's see for example Dr.Watson logs.
In winsys.ini we have this entry:
FileKey6=%allusersprofile%\Application Data\Microsoft\Dr Watson|*.log
In this way doesn't work for me.
I must edit that string as follow:
FileKey6=%allusersprofile%\Dati Applicazioni\Microsoft\Dr Watson|*.log
Tried some google searches, it seems doesn't exist in Windows any
environment variable available for "Application Data" and "Local Settings" :(
I see, so in IE internet setting and options, I could change the path to be the original english path for that.
I wonder though, why winspy can identify the index.dat + path properly.
This is from my registry:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Cache\Paths\path1]
"CacheLimit"=dword:0003c02e
"CachePath"="C:\\Dokumente und Einstellungen\\Tolomir\\Lokale Einstellungen\\Temporary Internet Files\\Content.IE5\\Cache1"
This could be a way to identify the location of the index.dat properly. If gives you the proper path to Content.IE5
Sorry, i'm not so skilled to help you in such kind of registry tweaks :(
Anyway, actually my CCleaner too doesn't detect and doesn't clean any index.dat file.
I can't see any index.dat file clicking Analyze. But using another application i can delete
index.dat (and also view their contents before and after reboot) with no problems.
So i think isn't at all needed make any Windows Registry tweak. Just wait and see
if some developer and/or skilled user can kindly give us some input... :huh:
Yep, that was directed to the developer(s).
Right now I've added that folder I've mentioned to the custom folders in CCleaner.
Still I would really appreciate some update for CCleaner (hey I'm a donator :-)
Thanks for your help, Whiteshark, though.
Tolomir
