index.dat files
Does CCleaner refer to the index.dat files as Windows log files? I have cleaned the log files out, has that deleted the index.dat files?
I do not think index.dat is cleaned unless you have
Internet Explorer History or Index.dat boxes checked off.
I didn't notice that there was an option to tick to clean index.dat files until you replied, as it was greyed out and I didn't look closely enough. Thanks for your reply.
Glad you got everything sorted :)
