Just after some feedback on what are other peoples perception of the uses/reasons with the INDEX.DAT file.
I was under the impression it is used mainly(if not solely) by Internet Explorer to record the usually stuff like cookies, history, searches etc. In other words, they record stuff of little importance in the grand scheme of things.
Add to that, if you never use IE or care about the info these files contain, I have never found a reason not to clean them from my PC's, or knowingly suffered a disadvantage in doing so.
Just wondering if I have missed some point to these files ???
Will cause issues with Help and Support if it's removed. There may be other index.dat files also that aren't even related to Internet Explorer at all that could cause a system-wide problem if removed. This is on XP though, I don't know the mess that's in newer versions of Windows.
@Andavari, can't say i've personally seen any issues, even in Help and Support, back when I had an XP PC. Your example maybe just limited to the offline files kept in OfflineCache.
i rememeber something years ago about PCHEALTH being tied into MSINFO32, something about deleting the contents of \PCHEALTH then effecting how MSINFO32 works(or doesn't work), but I don't suffer that problem either when I delete all INDEX.DAT files.
