Incredible FPS drop after using driver updater
Hello.
Yesterday after using driver updater to update some of my drivers, I encountered huge fps drop in games, my fps went from like 35-45 to 1-5 it's unplayable ;right after updating my screen resolution changed from 1600*900 to 1024*768 if it can help to say it, but I'm able to change it back to 1600*900 ; I don't have any system restore point.
When I encountered that fps drop I immediately reset my pc to original state with full cleaning options.
Nothing changed, and as I have reset my pc I can't restore the drivers to old state within the CCleaner app.
I searched a solution and I found I had to download old drivers I had before from the official maker.
I searched for "hp probook 4710s drivers" but I could not find those. I don't want to lose my Windows license key so I won't reset from an ISO file that will make me lose it.
My system information :
Microsoft Windows 10 Professional
10.0.19042 Number 19042
Microsoft Corporation
DESKTOP-L3LDH00
Hewlett-Packard
Model HP ProBook 4710s
Type x64
processor Intel(R) Core(TM)2 Duo CPU P7570 @ 2.26GHz, 2267 MHz, 2 hearts, 2 processors
Thanks to help me, any help is welcome.
Re-installing the same Windows version will not lose you your licence key as the key is digital and stored in the Cloud on the Microsoft Activation Server.
https://answers.microsoft.com/en-us/windows/forum/all/will-i-lose-product-key-activation-if-i-reinstall/7065c1a5-0ed0-4668-a926-09c56f7e48ce
1 minute ago, hazelnut said:
		<a href="https://answers.microsoft.com/en-us/windows/forum/all/will-i-lose-product-key-activation-if-i-reinstall/7065c1a5-0ed0-4668-a926-09c56f7e48ce" rel="external nofollow">https://answers.microsoft.com/en-us/windows/forum/all/will-i-lose-product-key-activation-if-i-reinstall/7065c1a5-0ed0-4668-a926-09c56f7e48ce</a>
I will re-install the same Windows version and I'll tell you if the problem is solved.
Thanks for your help.
Worked by re-installing the same Windows version from external hard drive , thanks for your help !
Good day
No problem.
Good to hear you are sorted now :)
