It appears as if Defraggler will not correctly report the volume size in the Properites area of the drive tab. I have a 18TB ReFS volume, it reports the capacity is 8,002,825,183,232 bytes but also that it is 16.4TB, and that there is 4,796,935,921,664 bytes free which also happens to be 13.5TB! I can only assume that the text box has it's horizontal size limited and is not rendering the left most "1"s which should be there even though there is ample room between it and the text box which says "Free space:" or "Capacity:". Please see the attached pictures.
If it matters the relevant parts of my system are:
Defraggler 2.18.945 x64
Windows Server 2012 R2 Datacenter (latest patches & activated)
SuperMicro X9DAE Motherboard (Dual Xeon E5-2650, 48GB DDR3 ECC RDIMM, UEFI mode, latest BIOS)
HighPoint 4320 3 Gbps SAS RAID Card with 8x 3TB HGST (HDS72303) disks in a 18TB usable RAID 6 (64k stripe, 4k sector) which is formatted as ReFS.
Edit:
Ugh, well for whatever reason the forum appears to be resizing my image to about 50% of its size. The relevant info which was displayed there is in my post above.
Edit 2:
I attched a second picture which will show how the information is displayed incorrectly.
