Incomplete Cleaning
I am running the latest version of CCleaner and when I run the cleaner function it reports 640 MB of files to be deleted.
However, when I instruct it to remove the files it only removes say 360 MB.
I then run the cleaner function again and it reported 0 MB for removal.
This never happened with previous versions of CCleaner.
The only new software I am using is Norton Internet Security 2008.
Has anyone experienced this and if so what can you do about it?
Hello cleanerlover,
Inaccurate figures have been reported in the current version v 2.03.532 .It reports less than was actually cleaned.May be fixed in next version.
Thanks for taking the time to report a problem.Good members info always helps improve the product.
:) davey
