Include folder pattern with wildcard possible?
In menu
Options-->Include
users can define additional files to be wiped.
But what if I don't want to specify the exact folder location but only a folder pattern.
Example:
In a directory tree
D:\appserver\
I want to wipe all folder sub trees which match the pattern *cache*.
So the following folders should be wiped for example
D:\appserver\mycache\
D:\appserver\foo\bar\cacheold\
D:\appserver\another\sub\folder\cache\
Unfortunately I cannot specify in CCleaner something like
D:\appserver\*cache*\*.*
or
D:\appserver*\*cache*\*.*
Mind all the *
Is this possible somehow else?
If not: Can this be included in the next release?
Thx
Thomas
You are a braver man than I.
Are you happy to assume that CCleaner will correctly understand what you meant by things such as
or
or would you want it to await confirmation for each target that it discover as being eligible for wiping ?
