Improvements for Drive Map display
In order to more clearly display the map of the drive, I suggest adding new zones.
For the record, the current zones are as follows:
Empty
Not Fragmented (Low Occupancy)
Not Fragmented
Fragmented
Reserved MFT Space
Page File
Files being read
Files being written
I propose adding and/or modifying zones, as follows:
Occasionally, blocks that show up on the map as Empty Space actually have (very small) files in them. This should be corrected by making blocks with ANY file entries in them appear as [Not] Fragmented (Low Occupancy).
There should be zones for "Not Fragmented (Full Occupancy)" and "Fragmented (Full Occupancy)". These would be the blocks that are fully compacted, with no free space between files. These zones are not as important as the Low Occupancy correction, but they are the logical complement. If you mark blocks that are completely empty, mostly empty, and mostly full, why not mark blocks that are completely full?
