Ignore issues
First of all, I love CC and have used it for several years with no problems (until now).
CC's issues scanner found an issue that isn't really an issue. In fact, allowing CC to fix the issue caused my wireless adapter to stop working. I re-installed the wireless adapter software and the "issue" came back but the adapter works.
My question: Is it possible to make the issues scanner ignore this "issue" in future scans? I know I can just uncheck it every time I scan and fix issues. I also know that eventually I'll forget and it will be "fixed" again.
Thanks!
