IE Url's not being deleted
Heya, I'm new to the forums; in fact, I just got CCleaner about 10 min. ago :).
However, I have a problem with the URLs that I have visted in the past not being deleted. Most delete just fine when I use "Clear History" as well as CCLeaner's history clearing ability, but some websites still appear.
This is what I mean.
I know I'm new to the forums, so I tried to use the search feature but it was futile for me :( (Unless I really suck at searching).
Anyone know what could be the problem? It's really annoying because, for example in the picture, that was an old URL that I used to visit some forums; the forums moved to a different URL name and so now I use the new website; however, the old one (seen in the pic.) remains; it's really annoying.
As I've said, 90% or so of the URL's properly get deleted when I use "Clear History" and whatnot but some sites like the above just won't delete.
Any suggestions? Sorry if this has been asked many times before; I honestly couldn't find it mentioned on the site, especially since I don't know exactly what to call this problem (therefore searching was difficult).
Thanks in advance!
Go to:
Start>All programs> Accessories>System Tools> Disk Clean up
Select your C drive and press ok.
Under the disk clean up tab see make sure temporary internet files is checked and press ok.
Let us know if they are gone.
Go to:
Thanks for the quick reply!!
I did as you mentioned; however, the URL's still pop up when I start typing them.. www...etc.
Should I check the other boxes in the Disk CLean Up besides just "Temp Internet Files"?
If you're comfortable editing the registry, go to HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\TypedURLs and delete the problem URLs.
Great! It looks like I got it finally. It seems like I just needed to restart the computer for some reason. Thanks rridgely.
And thanks Glenn for that information too; I'll keep that in mind in case if the problem persists, but everything looks okay so far :).
Happy to hear you figured it out. :)
CCleaner should be able to clean IE from now on so let us know if you have any problems with it in the future.
