IE 8 trouble...
I installed IE8 final on a Vista computer that never had IE8 betas before.
I ran CCleaner v2.17 with all options checked. I get 3 windows that say 'Delete Browsing History' popping up. With IE7, there was only one.
The windows close slowly. Why are there 3, though?
I really don't know what is happenig,
but I've had IE8 since RC1 and never had problems like this.
Maybe you should try internet options > Advanced > Reset.
It's not that bad. It did actually fixed me a problem with the address bar.
Yes me too I have the same problem.
By doing what metalj suggested wouldn't solve a thing. Since IE8 is recent, I can only guess that piriform need doing testing with it and update accordingly.
Actually the problem with IE8:
When acessing "Safety" from toolbar, and "delete browsing history", same amount of dialog windows popup when pressing delete button as we see with CCleaner.
I hope the next update be ran without 'Delete Browsing History' popping up.
