IDT High Definition Audio Codec
Hi
Currently running Win 7 Home Edition 32bit upgraded from Vista Home Edition 32Bit
I suspect somewhere along the line the upgrade was properly installed.
I was experiencing problems with changing Sounds Scheme t/4 installed as above as shown in Topic Title
Since installation my Device Manager indicates the attached message.
Can anyone please advice how to rectify the code 10 message.
Thanks
P.S. any further info required, hopefully will be able to oblige.
HI Guys
FOgot to actually image file with error code
It is now being attached
Tks
Have you downloaded the latest drivers from your Manufacturer's Driver website? Install the latest drivers and see if the problem persists.
Here is a list just in case: http://www.idt.com/?app=knowledgebase&contentID=3640&parentID=3640&parentPath=1210-3638-3639-3640
