If I restore my PC to a point before I activated my CCleaner Pro license, will I be able to activate it again? Will it use another one of my 5 licenses?
Thank You,
mbgraves2
Thank You,
mbgraves2
Just reinstall CCleaner if you still have the installer, if you didn't keep the installer then simply install CCleaner Free.
Then reactivate it to Pro - Options>About>Upgrade to Pro> enter key>Register.
If you need to download a new installer then it's easiest to find the latest one here:
https://www.ccleaner.com/ccleaner/builds
As it's the same machine then it will not use an additional entitlement, so you'll still have the others to use on other machines.
PS. As far as I know 5 computer licences are no longer sold, (although there may still be some old ones about on retailers shelves?), 3PCs and/or Macs is the norm for a Pro Plus licence.
