when i use nsa 7passes CCleaner keeps crashing on me what should i do?
Could you give a bit more info such as operating system and version of CCleaner.
im running CCleaner 1.41.544 and windows vista and every time i use CCleaner with nsa 7 passes on it crashes on me sometimes
Another user reported if he unticked the windows log files box in CCleaner, it stopped happening. Do you want to give this a try?
i tried it and it is working again
I have v1.41.544 and am running Vista (Ultimate) and CCleaner keeps crashing. I have unchecked the Widows File Logs and still it crashes. I can scan and fix issues but crash as soon as I attempt to clean. I am able to clean if I switch to Normal Deletion, however, I would like to use the NSA Deletion. Is there a compatibility issue with Vista and if so, is it being worked on for CCleaner v2? Any help or advice would be greatly appreciated. Thanks!
I am running the same version with XP Pro and I am having the same problem. I am only using 1 pass and it happens when I run CCleaner from the Recycle Bin without opening and analyzing.im running CCleaner 1.41.544 and windows vista and every time i use CCleaner with nsa 7 passes on it crashes on me sometimes
