can some on please give me a link for either CCleaner portable or recuva portable
thanks ahead
thanks ahead
Well recuva is already portable. All the installer does is put it in its own folder.
Just copy the .exe wherever you want it to go. CCleaner portable is found here:
Well recuva is already portable. All the installer does is put it in its own folder.Just copy the .exe wherever you want it to go. CCleaner portable is found here:
I gather CCleaner V2.0 will be designed ground up to be truly portable like Recuva.
