I can't disable Smart Cleaning
In Ccleaner 5.61 and now 5.63 I cant uncheck the Smart Cleaning
Could you give more details, and maybe a screenshot?
Just in case you don't already know- To make a screenshot press the 'alt' and 'prt scr' keys when you have CCleaner open and active. That puts the window content into your clipboard. Then in your next post press 'alt' and 'v' (or right click and select paste).
42 minutes ago, pepe9 said:
In CCleaner 5.63 There are 3 boxes ticked under Enable Automatic Browser Cleaning click on each browser and you get a drop down page click on disabled do this to all of them. Now click off Enable Automatic Browser Cleaning and click off Enable Smart Cleaning you do get a Warning Message click YES.
You now turned off Enable Smart Cleaning this is working for Me. if it does not work Reinstall CCleaner.
Good Luck Kas.
Ok I solved
First disable; " Tell me when there are junk files to clean" and then you can disable Smart Cleaning
