Hi,
How can I use CCleaner PRO Trial? I read "30 days", after install I see this: (check ss). I never install on this PC CCleaner then I don't know
Hi,
Hi DEDE, and welcome to the forum.
I'm not sure about that one.
Have you had any other Piriform Pro "Trial" products on that computer?
Dunno if that would cause the pop-up you have about CCleaner Pro Trial, but it's a thought. Maybe one of the other guys will have come across this before and provide some info.
I've edited the title of your topic by the way to make it clearer and hopefully elicit a better response.
If nothing is forthcoming from the other members, I'll point the Piriform devs to your topic.
