I did not know that CBrowser would be downloaded/installed with the last upgrade of CCleaner, and want to uninstall it. How can I do this without affecting other programs?
You should just be able to uninstall it as any normal application
Asked because I didn't know how to Uninstall programs. Eventually found an option in Control Panel to uninstall programs.
... and of course CCleaner itself also has a function under tools to uninstall software on your PC ...
