How to save "Advanced Report"?
Preface:
I frequently get this notification in Windows.
Running cCleaner Custom Clean does magic, and I’m good to go.
I know that regular normal computer use creates too many temporary or cached files, so I try to put these files on a drive other than C:, through links. (mklink.exe)
By going to ‘Advanced Report’ I can see what and where these files are.
Question:
How to save this report to a file so I can review the list of files outside of cCleaner?
e.g.
e.g.
You’re in ccleaner 6 there is no log save.
in ccleaner 7 you can export details as a comma separated value (CSV) spreadsheet)
Hah! D’OH! This isn’t a complete ‘solution’, but helps to winnow down the scope of the problem. Having selected a category, bringing up the list of files, right click a file, choose ‘Save to text file …’ and follow the bouncing ball.
e.g.
