I changed IE7 into IE8, bur ran into a lot of problems with IE8 and got fad up with it. So I changed to IE7 again.
As usual I did the CCleaner scan and also the Registryscan and removed what was found. (but saved what it did remove in a file).
While IE7 didn't work, I used the System Restore Point of one day before the change IE7->IE8. But that didn't help to. I did the 'search for damages and repair it' feature on the C-disc. No (better) result.
I removed with the REVO Uninstaller, IE7 completely, did a reboot and downloaded IE7 new. No better result.
I have heard of others with problems trying to get back to IE7.
Some programs may have the same names but from where you are I would use add/remove only for uninstalling IE7 again. Then download and install IE7 again with an "immediate" REBOOT. Do not try any cleaning or registry fixing at all for a couple of days. davey
P.S. I am not saying that you should not try System Restore prior to installing IE8 but I would try this first.
I have heard the lament that "you can't go back from IE8". How true this is,I do not know.
I do not use the Registry cleaner since I've been writing on this Forum. Only, when my PC starts up. CCleaner cleans the regular stuff and not the Registry's. (I think/hope).
When I this afternoon downloaded IE7, I did after that the Reboot.
Perhaps you are right with your remark "you can't go back from IE8".
Note: I don't want IE8, just IE7 as a backup system for FF.
Nothing left then try System Restore to prior to IE 8.
You can always go back but it may require WinXP re-install.
Good luck, davey Harry, you can always be on my team anytime !!!
I did a system backup prior to the IE8 download (I think, I hope )
Does this backup include the registry keys etc?
Worth trying or could it cause possible damage?
Yes, the System Restore has the Registry and hopefully the other files necessary to restore you back to that time. However , you must keep in mind that any Registry changes since then will disappear. If you don't change things very often then you should be OK. davey
Well, yesterday it was D-Day for my PC. I did put the Back-Up back on C. What I saw during the process made me smile a little, all my deleted files popped up again. When it was finished I clicked the IE Button, same Problems!
It seems impossible to get it fixed. It could be right, you're not able to turn back from IE8 to IE7 again.
Only other thing I can think of is At Internet Options > Advanced tab Click on Restore advanced options and try IE. If that does not work then At Internet Options > Advanced tab Click on Reset to reset all IE Explorer settings, etc.
Good luck,
davey
P.S. Other than what YoKenny reports below you may also want to review this MS Blog site. I don't know what was on your system when and if you went to SP3. Note all that is said as regards IE6,IE7 and IE8.
I think I'd try this as a last resort before formatting and reinstalling, albeit it is a trial program but it "may help." Definitely worth making a restore point before using it though!!!
Good luck,
davey
Thanks! I will try this to when noting seems to work/help.
