vspica
1
Is there a way to reset all settings to their default without uninstalling and then reinstalling?
Using CCleaner Pro v6.04.10044 (64-bit).
Thanks
If I want to reset anything under the Windows or Applications categories, I just right click on the blue headers and select 'restore to default state'
![Screenshot 2022-10-03 144157.jpg]()
