There is no place to register. They have auto renewed my subscription and sent me an invoice. The key is the same number and no place to put it. This seems like an every year problem. I have contacted them a bunch of times (email) then it gets fixed for another year. Now this time I don’t know what to do. I can’t email them now.
If it’s the same key it should just autoudate the time left
It isn’t. It says that I have 19 days left.
@Laurence_CCleaner should theirs reset like i said? Do they need to wait for servers? Are they going to be hit with a donut hole where they have no coverage (that would be kinda bad)
Hi @mounttanman,
I can see from our records that you contacted our support team, and they reported you were able to activate the licence.
Please confirm if your issue is now resolved.
They were able to fix the problem. Like I said to them,this is an every year thing. This year he had to get in my computer and he deleted the program and reinstalled it so it would take my license key. Now it doesn’t say I have 19 days left on subscription. Till next year.
Thanks Mr. Tech
