How to pass cache web sites ?
when i clean chrome with ccleaner its disabling notification on twitter and logout web.whatsapp.
i already put twitter and web.whatsapp keep place. but its still not help. is there any solution for this?
i want ccleaner must pass everything about twitter and whatsapp
when i go custom Clean>Chrome>internet cache
if i unclick there then its working good but then all internet web site cache will not clean. i only want to stay whatsapp and twitter. there is no way ?
The first question is when actually cleaning do you run Health Check or Custom Clean?
To use customisations of what will be cleaned or not cleaned then you have to use Custom Clean.
Health Check cannot be customised and will always use it's own rules.
i always use custom clean. its my chrome setting. i need to uncheck internet cache . then ccleaner not touch twitter notificatipon and whatsapp.
if i click internet cache box and filter twiter web site whitelist cookies place. its not working . i tried anther versions too ccleaner
Try this
Rightclick internet cache and choose analyze
Double click on the result if in advanced report and not details immediately
One of those files is going to be in need of right click> exclude. If there are too many then clean it first then immediately load the twitter page that gives notification and nothing else (no other auto open pages or what not) then redo my steps and find the culprit
2 hours ago, Nergal said:
		Try this
		One of those files is going to be in need of right click&gt; exclude.  If there are too many then clean it first then immediately load the twitter page that gives notification and nothing else (no other auto open pages or what not) then redo my steps and find the culprit
Yes exactly what i wanted. its worked twitter but its not working for web.whatsapp. i used all cookies whitelist for test whatsapp still logout
Try this
Make whatsapp in working order
Right click on session under chrome and choose clean
Does whatsapp still work or broken
If still works try this for each option under chrome until you find which one cause the breakage
Then analyze that section as you did above finding the needed exclude
		<span style="background-color:#ffffff;color:#382e23;font-size:14px;">Right click on session under chrome and choose clean</span>
Where i find there ?
are you speaking about here ?
Nergal means Session under Chrome in CCleaner.
		Try this
i cant clean sesion while chrome working. ccleaner saying me skip clean or close chrome for clean session
Yes you have to close Chrome.
You cannot use CCleaner to clean the browser when the browser is running.
