How to keep most visited websites in Chrome
Each time I've used Ccleaner, my most visited sites in Chrome are gone from my start page.
Which setting is needed to keep them?
If you are using Custom Clean then untick 'Internet history' for Chrome.
If you are using Health Check then you need to change to Custom Clean to have more control over what gets cleaned or not.
Options>Settings>CCleaner home screen
Note that changing things in Custom Clean will not change what Health Check will clean, HC does it's own cleaning list regardless
1 hour ago, nukecad said:
		Options&gt;Settings&gt;CCleaner home screen
Aha, that works, thank you very much!
