how to get ccleaner to clean other applications
is there a way to get ccleaner to clean a application that is not on the applications list?
thanks
Yes, you can specify it as an 'Include', but you must know the filename and path of the actual file that you need to remove.
You can't just specify the application name and expect CC to know what bits to clean and what to keep.
https://www.ccleaner.com/docs/ccleaner/using-ccleaner/including-files-and-folders-for-cleaning
Alternatively you could use winapp2.ini which has cleaning rules for most applications out there.
It's a bit of an advanced use option though.
