How to Clear "Recently Opened Documents" ?
CCleaner doesn't clear this one.
Hi jkpatel8, and welcome to Piriform.
You don't stipulate where the "Recently Opened Documents" are, meaning they could be the ones listed in the "Start Menu", or you may be referring to "Recently Opened Documents" lists found within some Windows Applications.
Make sure you have "Recent Documents" checked in "CCleaner\Windows\Windows Explorer", and also "Other Explorer MRU's" in the same section.
See if that works for you.
