How to clean browsers without notification
When I close a browser I get a pop up box claiming my browser was cleaned when closed. It is annoying and I would like to eliminate it. Does anyone know how to do it?
Update- I found what it was...clean browser without notification!!!
thanks
hello granadamike,
perhaps "smart cleaning" is activated
you can deactivate it:
ccleaner -> options -> smart cleaning -> disable both
note: if you do this, you must start ccleaner manually to clean your pc
To disable "browser cleaned" pop-up, go to Options, Smart Cleaning - then you will see a listing of browsers with a drop down list for each. Click on the drop down list for each browser and choose "automatically clean on closing without notification."
It is unwise to uncheck Smart Cleaning, as it will not automatically clean your browser(s) and you will need to do it manually instead. Kind of defeats the entire purpose of having professional version.
