How to add custom rules to winapp2.ini?
Hi, if I add my own rules to winapp2.ini, won't they be overwritten when I next use CCEnhancer to download a new winapp2.ini?
How can I add custom rule below so that it doesn't get overwritten? Thanks.
[System Profile Tmp Folders *]
DetectOS=10.0|
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
Default=False
FileKey1=%WinDir%\System32\config\systemprofile\AppData\Local\tw-*.tmp|empty.check|REMOVESELF
This cleaning rule is already in the Winapp2.ini (220615):
[System Profile Temp Folders *]
DetectOS=10.0|
LangSecRef=3025
Unfortunately I can't answer your question, you would have to ask in the forum of the developer of CCE.
1 hour ago, APMichael said:
Thanks. I looked, but did not see it.
