I have been looking for a good reg cleaner and am new to CCleaner. How often do you suggest running CCleaner? I noticed that I clicked analyze and it found and cleaned 16 MB of crap. Then I surfed the internet for like 15 minutes and scanned again and it was already back up to 12 MB. So how useful is this program if all those unwanted files build back up so quickly?
Also, are there any things I should consider NOT analyzing and cleaning? I really would like to save my passwords and autoform entries, but is that safe?
.....Me myself dont use it all too often, once every 2 weeks or once every month is probably fine for me.
You have the right perspective. Much of this "junk" is self-regulating cache or log file content. Perhaps lowering the size of these caches would be less time consuming then over-CCleaner'ing.
I run Cleaner when ever I remember to, which is about all the time I think they should make it so the files it removes just cant be created in the first place. Problem solved
