How hot can it be?
Hi
As per SIW and Speccy`s diagnose:CPU is around 56 degrees (celsius) Please advice if CPU`s(AMD ATHLON dual core) temperatures is OK under that temperatures considering it is summer here and PC well ventilated.
Thanks.
That's 132.8 Fahrenheit. Perhaps check AMD's support site for documentation.
Hi
Thanks.
Hi,
to give you an idea mine is:
INTEL CORE 2 DUO E 6400 is at 41 celcius
Graphic card: NVIDIA GE FORCE 7950 GT is at 54 celcius.
Have a nice day.
