How Does CCleaner Compare to {product name removed}
I just got a trial copy of {product name removed} and would like to know if anyone has tried this software? If so, how does it compare to CCleaner and which is the better product?
This is an offical Piriform/CCleaner forum and as such is dedicated to CCleaner and other Piriform software.
Did you not realise that any reply on an official product forum is likely to be a tad biased toward that product? (And that plugs for rival products will be removed).
There are plenty of comparison sites on the internet.
A note of warning on comparison sites though is that:
  1. For any product, comparison websites monetise from sponsored advertising and affiliate commissions on a percentage of referred sales. Ranking, at last in the top 3-5, tends therefore to be based more on how much the site is given as a cut of sales, rather than actual product differentiation. Since CCleaner has a very popular free edition, I will let you draw your own conclusion on how that might play out.
  2. CCleaner has a user base larger than the population of most countries - which makes the search term "ccleaner" excellent clickbait for sites promoting products you have never heard of before. See point 1, above.
