How do I make an added search engine default?
I added google.ca in the search engines, but I can't make it to be the default. Is there a trick?
Thank you!
I prefer google.ca over google.com because the latter does not allow to filter on country. Any ideas how to make an added search engine the default?
See the CCleaner browser documentation (you might want to bookmark it for future reference).
https://www.ccleaner.com/docs/ccleaner-browser/using-ccleaner-browser/search-provider-settings
Thanks nukecad, but the documentation doesn't show how to make an added search engine the default. It shows how to add a search engine, but it is not accessible to be added as the default search engine?
I don't use CCleaner browser myslef, but that page I linked says - "To change the default search provider:"
Is it not doing that?
