How do I clean (delete) cookies?
A newbie to CCleaner, I am trying to clean out many cookies I neither need or want. Having moved the cookies I want saved to the Cookies to keep column I am unable to determine what button or command to push to delete the cookies I wish deleted.
Will someone help please? Thank you
Hello and welcome,
Firstly go to the cleaner tab
If you are using internet explorer you should see its the top listed on, make sure cookies is selected.
If you are using firefox, click the applications tab, which is next to the window tab and make sure cookies is checked.
Then just simply click run cleaner, make sure all browsers are closed
