I've been using ccleaner since it was beta and was called crapcleaner. It's a great utility. However, ccleaner 6.09.10300 added a new landing screen (see attachment).
Question: How do we disable this landing screen and immediately land on the one that counts?
I would suggest you have a look at the Settings in the panel on the left and make sure that Custom Clean is chosen and that you turn off EVERYTHING in Settingsthat you do not want.
After a quick check I see that when I turn off automatic updates etc in Settings/Updates, and then I go to the Smart Screen option and turn it off I get this warning saying it will stop automatic updates. Silly me... I thought that is what the Update settings were for.
Hi Hazelnut - Thanks for the quick response. I already have the items I want cleaned marked in Custom Clean and the ones I do not want cleaned not marked. Also, I have never used automatic updates.
