How can I edit the options in the right/click
folder drop down menu. I want to remove "Browse with Paint Shop Pro 8", which one of my children had used the trial version.
my computer/drive?C/documents and settings/folder with your name/send to/ delete the entry to which you refer.
If you'r feeling brave you can search the registry for the exact phrase that the program left behind. Then just delete it, but be sure to back up the registry first.
There's a great program that cleans context menus for you. When I find it I'll post a link.
You may want to try RegCompact which will clean your registry of old, obsolete strings. CCleaner might be able to help too with the Issues tab.
Found it. This should do it.
http://www.nirsoft.net/utils/shexview.html
And that is why I read forums.I learn!
Thank You nod32, however, believe it or not, I can't find it in the list. I disabled several context menu listings to make sure I was looking for the right thing and the program works fine but it just isn't there. I also searched the registry with reg seeker for anything Paint Shop Pro 8 and deleted everything it found. Oh well, no big deal!
Well it's gone! I can't believe it. Here is what I think happened. I had conducted a registry search for Paint Shop Pro 8 with RegSeeker and it found about eight or nine references. Now you must understand that I uninstalled that program months ago and have cleaned the registry dozens of times since. Anyway, I run RegistryMechanic (just because I had downloaded the ShellExView program) and it finds about six references to Pro Shop it had never found before. Then I go to issues in CC and it finds a reference, so I clean italso. Then I check the drop down menu and the "Browse...8" is gone! Crazy! It just proves that multiple cleaners is a must. It's like RegSeeker loosened it or something and RM and CC finished it off. lol
That's good, show the invalid keys no mercy!
