is there a hotkey to run CC .. for example .. Shift + C or something .. if there is .. sorry to post this .. but if there isnt .. please add hotkeys to CC .. for easy cleanup .. thank you
Not by default there isn't. I tried Shift+C like you had but that isn't supposedly allowed it defaults to CTRL+ALT+C.
All you have to do is right click the shortcut for CCleaner then input a hotkey. Like this:
thank you
Forgot to mention:
You can also use the /AUTO parameter to have CCleaner automatically clean:
"C:\Program Files\CCleaner\CCleaner.exe" /AUTO
