Hotfix Uninstaller cleaning option is missing in 2.33.1184. Screenshot attached.
Sorry if this has been reported already
It's there for me. Running Windows XP.
Which Operating System are you running?
I'm on XP but I believe Vista and Win7 don't use Hotfix Uninstallers in the way XP does, so there's nothing for CCleaner to pick up, hence the missing Item and Checkbox.
I might be wrong about Vista, but I'm pretty sure this is the case in Win7.
In the Hotfix uninstaller winsys.ini entry, DetectOS is set to |5.2, which means WinXP or older (WinXP's kernel number is 5.1). No Win7, and no Vista either
