Homepage changes after using CCleaner.
I have recently started to use IE 8. After I run CCleaner, I have to rearrange, add/delete content on my MSN homepage. This did not happern with IE 7. I have moved the MSN cookie to the righthand side column in CCleaner so it is not deleted. No change. I have been using Win XP all the time. Does anyone have any suggestions? Thanks.
I dont have a single MSN cookie and I just visited msn.com and I was already signed in. Live and MSN are one in the same to a degree. Try adding Live sites to the cookies to keep list.
I've added everything that has 'live', or 'bing' to the keep list, then ran CCleaner and the same thing happened to the homepage. Ugh!!
Which version of CC are you using?
Im running CC v2.25.1025 and IE8 on Win7 x86. Maybe that info whill help someone else try to figure out whats going on.
I'm using CC v 2.25.1025, WinXP sp3, IE 8
