After running CCleaner all my home page presets are lost, for both IE and Firefox. Which option in the cleaner is causing this????
Help
Help
Help
Hi Randy,
If you are using Advanced cleaning options then turn them off or get used to many preferences being reset to defaults.
If not then supply more details about your problem.
Good luck,
davey
Hi Randy,If you are using Advanced cleaning options then turn them off or get used to many preferences being reset to defaults.
Good luck,
davey
Davey,
Not using advanced options, using google toolbar on both browsers home pages..........
Randy
