The newest available version v5.05.5176 (23 Apr 2015) lists
- Improved DPI awareness and high DPI support.
- Minor GUI improvements
As you can see in the printscreen, the High DPI support is a little bit better (no more pixelated icons), but the icons are now splitted in two halfs and different icon parts.
Could you please improve it again for screens with high DPI? Thank you!
system
April 23, 2015, 5:08pm
2
Hi, please could you re-download 5.05. the issue should be fixed
You are right!
NOW - after downloading the new version with the same version-number - all this icons looks fine, even with 125% font size.
Thank you for this incredibly fast fix!
mta
April 23, 2015, 10:35pm
4
looks like it now may be time to move from v4.19 to v5.05
Mike1
April 25, 2015, 6:07pm
5
Indeed. Still prefer the v4 look and feel, but with this DPI update v5 is tolerable.
mta
April 25, 2015, 11:30pm
6
agreed.
have made the move to v5.05, and it's OK, but not great. (that white title bar really is very average)
tolerable - or maybe useable - would be a good term.
Mike1
April 29, 2015, 10:38pm
7
Two small things I've noticed that could do with a graphics update.
The installer itself also shows a slightly pixelated pear, but then we're really nitpicking.
Mike1
August 4, 2015, 7:12pm
8
After having upgraded to Windows 10, I decided to revisit this topic. I noticed how similar CCleaner's top looks like the Windows 10 style.
Surely it's time to use native Windows 10 elements instead of CCleaner's own? The Windows 10 elements look superior to CCleaner's.
Although in general Windows 10 needs some more color at the top and a thicker window border.
You have me thinking about trying it. I'm also still on v4.19.
Is it possible to reinstall v4.19 over the top of v5.05 if I want to go back?
Nergal
August 5, 2015, 5:17pm
10
Indeed. Still prefer the v4 look and feel, but with this DPI update v5 is tolerable. ;)You have me thinking about trying it. I'm also still on v4.19.Is it possible to reinstall v4.19 over the top of v5.05 if I want to go back?
Yes (if not just uninstall 5 and reinstall older)
If you're using Windows 10 or plan on upgrading I wouldn't even bother with the v4 anymore, go with v5 for more up-to-date compatibility.
I am staying with Windows 7.
