I keep getting this error when I try to run CCleaner. I tried reinstalling, it didn't fix it. http://i.imgur.com/9mG1Ovt.png
if you search the forum, others seem to also suffer this fate.
for them, renaming ccleaner64.exe to something else fixed it, try that and see if it helps you too.
otherwise your choices are; uninstall, reboot, reinstall. or try the Slim or Portable builds.
Renaming it seems to have worked, thank you.
Is this where I can ask questions about CCleaner?
You are encouraged to start your own topic
http://forum.piriform.com/index.php?app=forums&module=post§ion=post&do=new_post&f=4
