well i posted a question on here earlier and so far no one has responded!!!
i am by no means a computer "geek" but i wish i was and then would not have to ask such dumb questions.
it is regarding the downloading of the most current version of CCleaner.
i did it last night but when i check to see what version i have, it is still showing the old one. Am i to "run" it from the exe file that is under my program files??
just want to make sure i don't screw anything up on my computer, and i love CCleaner but i just want the newest version they have 2.25.1025.
thanks for your help with this Hazelnut. I will hopefully be able to try this tonight. kind of hard to do computer stuff with a 4 1/2 year old running around, usually do stuff when she goes to bed. thanks again i will let you know the outcome tomorrow if we try it tonight.
