HELP!
I just bought a new computer and was following some directions on using CCleaner to get rid of some bloatware. I went into Tools and selected programs I didn't think were necessary and instead of selecting the uninstall option I selected Delete Entry. How do I view those programs in order to permanently delete them now? The aren't listed anymore in CCleaner or in Add/Remove programs
Thanks
Most programs are kept in c/program files (on xp anyway)
Go there, open the program folder of the program you want to uninstall and look for uninstall.exe.
Also if on xp look in start>all programs and see if they are listed there along with their uninstall option.
