Help with RoboForm please!
So years ago I dumped RF for Firefox extension InFormEnter. I actually preferred the control IFE offered, i.e. one field at a time and unlimited saved entries. Recently though, if I want to enter a sweepstakes some of them have numerous individual fields, e.g. phone 000 then 000 then 0000 or date of birth mm dd year. So I've installed RF. The problem is that I've set it up (at least I thought I had) to not badger me with pass card requests every time I try to login somewhere but it keeps doing this. I can't find it in my auto start programs to disable, I can't find it's service to change to manual, nor can I find a process running and I disabled the Ff RF extension. So did it install a driver? I only want to start it when I need it. How can I stop this fool thing? Thank You!
First,what version RF currently are you using ? Free or Pro version ? what OS are you using ?
If you have already created a number of password-protected passcards,you can remove password protection from them by going to RF toolbar (in FF) ->option -> security -> clicking Set Master Password,Mass Protect/Unprotect ->check Remove Master Password -> OK
I use RoboForm2Go / portable version and no problem at all.
