I Have Tried it on 3 computers so far and on every one the same error came up ,please chech the attachments
its not letting me upload nattachments
still nope
Can you give a bit more info as to what happens (e.g it gets to 65% then freezes.) until you manage to upload the attachment.
Also have you tried uploading using a different browser perhaps.
Hi
You cannot attach "dangerous" files.
Most forums list what can be sent, but I find no clues here.
This site VERY clearly objects to any *.exe" file.
What were YOU trying to attach ?
You may be lucky with a *.zip
Alan
it loads to 100 and then stops and when i try to post it says its not finished yet
anyway mabie you can help me . i have tried this program on 3 computers and when i try to do deepscan on all 3 it says something like
error]:range check
error]:range check
and i get cycle redundicy check too
A
II
sorry spelled rong
I almost ALWAYS has a temporary freeze at 100% completion of a download from many sources.
Windows Task manager process tab shows me why.
My anti-virus has taken over and is scrutinising what I got before it lets me (or Windows) have it.
You need to launch Task Manager and click on the CPU column BEFORE the download,
then when you freeze at 100% completion you can see what is taking all the CPU cycles.
Another possibility is that your THREE computers COULD be fed from ONE common hardware router/firewall,
in which case perhaps that has decided to block the last percent.
Or maybe your I.S.P. is blocking.
So many possibilities. So little information upon your computers and security configurations.
Alan
